Solved - Mean Well MPM series
Mean Well MPM-10
I have used Google and the forum search but have not been able to find an MPM-10 series part.
The MPM-05 series seems to have the same footprint, so I guess one part may catch both.
Name of the partâť—
Top viewâť—
<This picture shows the part from above, so that is easy to see were connectors should go, and which diameter they have.>
I would assume a 1.6mm hole/via should do fine.
Datasheetâť—
manufacturer’s datasheet. Here, a link is fine.
Mean Well specific as per drawing
[ x ] Other (please specifiy) PSU module PCB mounted
Thank you in advance
The IRM-05 has the same foot print and can be used.
