i noticed there’s a few parts, e.g. “hole” (pcb), that have an “advanced settings” section in the inspector where you can enter arbitrary values that affect the part.
can i provide advanced settings for my own custom parts?
for example, there is a huge range of terminal blocks, headers, and board-to-wire connectors that can be completely parameterized as:
- silkscreen rectangle width / height
- offset position of first pin in silkscreen rectangle
- number of pins
- mounting pitch
- pcb hole size
- pcb ring size
(even more if row count + column count is included).
it gets pretty tedious having to define completely new parts when the pin layout isn’t available in some other part.
but this would also be useful for other parts besides connectors.
can i do this? like, i don’t know, have variables in the svg that are bound to fields in the inspector or something?
