I am just looking at using fritzing and would like to use parts such as the rfid rc522 shown
here.
Is it possible to use this on the breadboard page? which one do I use? how do I get it to show on the breadboard page?
Thanks.
You may need to create an account in order to download files. There is a green “clone or download” button which will then show up on the right hand side of the screen, just above the list of the files.
I get that, I click on it and it loads a file into my computers download directory. I don’t know were to put it from there?
I assume it is the PNG file I need but all the files in frizing are svg files and there isn’t one on this page
if you right click in the parts library area on the right side of the screen and select “Import”. The ou should be able to direct your computer to your download directory and click on it
.fzpz you import into MINE bin
.fzz you open with File/Open
Thank you smilliken that did it. I now have the part in myparts section of fritzing. Thanks for your help. Problem solved, I never even saw the import button
thanks Old_Grey if I come across any of those I will try that.
