Hey, does anyone has a library for this module or something similar?
I just need a 5v solar charger module so that I can connect my 18650 lithium battery, solar panel and arduino to it.
This is the link to the module description if it helps: CN3065 Mini Solar Charger Module
This part should do what you want. Note pcb is probably not quite right as it was made from a jpg image. Print out the footprint at 1:1 scale and compare it to a real part to check the footprint. As well this web site has a schematic for this board (quite rare!)
CN3065-Mini-Solar-Charger-Module.fzpz (9.9 KB)
