Soil Moisture Sensor Module
Someone requested for a part like this:
So here it is:
Fritzing Part
Soil Moisture Detection Module-improved.fzpz (25.6 KB)
@Hans_Werner_Atzenhoe please stay tuned for any updates.
Hans Werner Atzenhöfer, Bitte bleiben Sie für weitere Updates dran.
The analog and digital pins are reversed. Could you update the part please (I could do it, but then there would be two parts different parts and you replacing the original will be better!)
Your part has DO AO rather than AO DO as it should be in breadboard and schematic.
Schematic is still wrong.
and it is preferable to replace the original part (with an edit saying you have done so) in the original post so there is only a correct version in the forum rather than an incorrect one followed by a correct one.
OK, I edited the post. Sorry, I forgot to load the updated SVG
