I am looking for a wide 20 pin IC socket and can’t find one anywhere.
This surprised me (that standard IC sockets don’t already exist as a core part) as I would think it would allow faster design/PCB work as you would not need to create a custom IC or development board part every time, just select the appropriate size (standard/wide and # of pins) IC socket, drop it on the bread-board and away you go. These as standard parts would also ensure that the PCB specs (footprint/holes) were right (vs trying to use two header pin sets and getting the width right).
Did I just over-look it?
DIP IC sockets, standard and wide format, 20 pin (others too).
Previous work, similar parts
Was not able to locate anything that looked relevant.
change the pin width in Inspector (the lower right window where the green arrow points. That also changes the number of pins and a number of other parameters.
