I would like to create a part that is the lower half of a force sensor. It just consists of two intertwined copper traces and a connector for each. The traces may look like this:
I have seen quite a few tutorial on creating parts, oblong pads etc., but I must confess I did not find a clue as of how to achieve this:
- the traces and spaces between must not be covered by the solder mask or silkscreen prints - a square convex hull without any covering will do
- the size shall be adjustable, scaling the SVG as is required, but leaving the connectors intact.
- the schematic shall show it as a variable resistor
- there is no breadboard representation
Can you give me some hints where to look for parts or even all of the staps to a solution? Any help is highly appreciated.
