Nope does not align. I tried every smd part I could find on the interwebs, though I hadn’t found that one This is also a stereo part (just 3 pins but sleeve, ring, tip). Thanks though
Check it carefully. I corrected that part later for some reason but I don’t remember what was wrong with it. For some reason it doesn’t show up in most searches, I had to use the .fzpz file name (which I had externally to Fritzing) to get the forum search to find it and a google search doesn’t appear to find it at all.
