Seeed Wio Terminal Fritzing Part?
Hello, looking for a fritzing part for the Seeed Wio Terminal?
Link to Wio Terminal description: https://www.seeedstudio.com/Wio-Terminal-p-4509.html
@vanepp If you can provide the Fritzing part, please make sure that the grove connectors on bottom of Wio Terminal can be connected to grove sensors.
This should do what you want. pcb is suppressed as unneeded, and the grove connectors may be in the wrong order (it isn’t clear from the pictures which way pin1 is.) If so flipping the connector horizontally will fix it.
seeed-wio-terminal.fzpz (10.8 KB)
Thanks for all of your help. I have all the custom parts I need for my design.
