Security system
need please for wiring for it using the main components
(Arduino uno, esp32 cam, 2 servo motors, buzzer, rotary encoder, sim900a)
where, when twisting the rotary encoder automatically the 2 servo motors turn to 90 degree and the buzzer alarm and the esp32 cam capture 3 picture of the intruder and save it in SD card then lastly the sim900a send an alert message that there was an intruder.
Most of the parts should be found either in core parts (search using the search bar at the top of the parts bin) or via a google search of the form “fritzing part part_name” (i…e. fritzing part esp32 cam" for instance.) Once you have found the parts then you need to connect them together to do what you want.
