Hey there
I’m searching for this SSR parts.
The only one i found was here but only for a single relay.
Are there any other sources?
Thanks.
Hey there
Thanks.
There doesn’t appear to be a part other than the one you indicated. To make a part we would need to know how many relays you want (the product page has multiple models …)
Hi Peter,
i need one with 8 relays on it and one with 4 relays on it.
It would be great if someone could make it.
Greetings
These two parts should do what you want. The mounting holes are likely not exactly correct as the position was determined from the jpg images on the web site …
omron-relay-module-4way.fzpz (16.7 KB)
omron-relay-module-8way.fzpz (24.0 KB)
Thank you very much.
Regards
Sorry, do you have with 2 way?
There is a two relay part here
I don’t know if it is what you want or not though.
sorry, do you have omron relay module 1 way?
A google search of the form “fritzing part 1 channel relay module” will find the existing parts that are available. Otherwise there isn’t enough information to identify what part you want. A web site referencing the exact part you want would be more useful.
