I’m new to fritzing and spend a lot of time searching for the HF41F Relay or something similar. But I couldn’t find.
Would be great, if someone could help!
The part here is likely as close as there is
If that doesn’t do a data sheet for the relay you want would be required (images are basically useless.)
Hi, thx for the quick response!
Unfortunality the kf0604d isn’t matching. And now I see, that I didn’t posted enough information.
Exactly I have the HF41F-005-ZST. It has 5 pins (Layout C).
Here you can find the datasheet: HF41F_DB_EN.pdf
I also try to upload the layout as png:
The data sheet is fine. You however need to specify which of the variant you want vertical of flat pack form a or form c as they are all different.
I have the vertical one in Form C.
Erik.
Hi!
Is there some update?
I haven’t yet had time to get to it. It will likely be a few days yet.
Hi Peter,
this is great! Thank you very much!
