Somebody having a 10V battery? Or is there a way to make with the basic components in Fritzing?
I was going to say you can change the voltage via Inspector, but it doesn’t appear that you can. !0V is an odd size for a battery though, 7.4 (LIPO) 9V 12V are more common. It is fairly easy (for me at least) to change a battery to be 10V (I may even consider making its voltage setable if I can figure out how.) Do you have a data sheet for the battery if you need breadboard to look like the real thing?
