does anyone happen to have this RJ45 port as a friting part?
Thanks Andy
There are a bunch (with and without magnetics as I recall) in core parts. One of them may do you. Entering RJ45 in the parts search window will bring them up.
Hello Peter,
thank you very much for your quick reply.
Unfortunately, the correct ones are not available in the core.
The website doesn’t have sufficient information to make a part. I would need a mechanical drawing with the location of the pins, there spacing and location of the tabs (and their hole sizes) and the connections to make a part. The datasheet for the connector would usually have that, but a google search for “uxcell rj45 connector pcb mount datasheet” doesn’t turn up anything useful.
Hello Peter, thank you very much for your efforts. I have found a data sheet that matches this RJ45 connector.
The PDF you can found under:
RJ 45 Connector
Regards Andy
This part may do what you want. The pin numbers may be wrong as there is no indication of pin numbers in the data sheet so I copied one of the other rj45s. The slots are implemented as holes as Fritzing doesn’t support slots in parts in most cases and are set as solderable as they appear to be for the shield.
KH-RJ45-59-8P8C.fzpz (8.2 KB)
