perhaps I have overseen a part but I assume there is no Header 4 with 2.54mm format available.
I need only 4 pins in a row which I can add to my project.
Adding 2 * Header 2 is not an option because I irritate myself when I rotate or move such header.
I’m not sure what header you are talking about.
If you mean the standard (female by default) header part, then you can set the number of pins in the inspector. The default is two, but you can set any number, e.g. 4 and get a 4 pin header.
