Hi, has anyone made this RushFPV GNSS Mini module for fritzing parts? I hope someone can help me on this.
Thank you.
Thank you.
I would need the exact dimensions. Do you have a datasheet for it, or could you measure the part for me? I need the outer dimensions and the precise measurements of the four pins. For the pins, I need the size and exact position, ideally accurate to 0.1 mm.
Regards, Harald!
Hi Harald,
I understand you need the specifics for a Fritzing part creation.
The only official documentation I have is the attached datasheet, which lists the outer dimensions as 18mm x 18mm x 4.8mm. Unfortunately, it does not provide the exact 0.1mm coordinate mapping for the four pins (RT, LT, V, G).
I only have this information at the moment. Is this enough for you to work with.
The four contacts, however, are not in the right place in the PCB view. This means the following:
You can’t manufacture a circuit board on which the component is soldered.
It looks like it can also be plugged into a socket.
How are you connecting this component to the rest of your circuit?
I’ll sit down and work on that part over the weekend.
Best regards, Harald!
