Hello!
I’m trying to create my first PCB and needs to use both copper sides. in the Inspector the PCB1 is set to “two layers”, but I can not select both coppersides at the routing menu.
This problem does not exist with a new project, but i have invested a lot of time in my first layout … Is there a hint ?
thanks a lot
Kris
Found a solution … (really simple!)
delete the PCB1, insert a new one with both layers
so simple …
kris
