Round PCB Board
Is it possible to design a round pcb board in Fritzing?
Yes. You need to generate and load an outline svg file however. Assuming you don’t need slots that is reasonably easy. Instructions are available by searching the forums for pcb slots there are a number of posts detailing how to do this.
It’s also possible act like this.
-select the pcb (unlocked)
-on the tag “shape” select from the list “elipse”
-choose width=heigh (ad es 60 and 60)
Tommaso
Good catch! I looked at the ellipse, (but he wanted a circle) and didn’t think of trying to change the height/width which indeed produces a circle. That is a much better and easier solution than trying to load an image!
