Hi all, i need a RJ45 90º Jack with 8 pins. The dimensions in mm could be as this image:
Thanks for any help!
Make a search into parts with keyword “rj45”, and you should find a part with this footprint.
Wali
I already did it. All that ive found are with a diferent dimensions.
Ok, I didn’t checked dimensions…
I’m sorry, I can’t help you making a new part design.
But if the size is not critical for your project, you may choose a connector which corresponds to the part ?
Like this one: http://www.velleman.eu/products/search/?q=5410329222574&jump=Fiche
