RGB LED Module Fritzing part
We would like to share the Fritzing part for DIYables RGB LED Module.
You can download it here: DIYables RGB LED Module Fritzing Part — Import into Fritzing to draw wiring diagrams and breadboard layouts with this board
Hello DIYables,
In Fritzing breadboard view, legs should be colored
grey : hex 8C8C8C : rgb 140 140 140
This is important, because the red color you are using indicates an open contact.
A part with a red leg therefore could be missread as an improper connection.
The schematic view of the part uses a 115mil long connector.
The schematic grid is 100mil, and connectors should try to match that length.
For this specific part, Fritzing still algins, and even flips it as expected.
The longer connector might however cause issues if this i copied by other parts, or if you use connector on two sides of the schematic block, in which case Fritzing can only align one side to the grid.
Schematic, with an IC placed on top for reference:
Dear KjellM,
Thank you for pointing out the issue.
I fixed and updated the download file.
