Hey guys i need a part for fritzing for an RF 433MHz Module for both transmitter and receiver.
Name: 433MHz RF Tx-Rx Modules
Filling in the template that you ignored would get you a better answer (pictures are basically useless in a parts request!) but a google search of the form “fritzing part 433MHz RF Tx-Rx Modules” (which is the best way to find existing parts) turns up a variety of hits one of which may do what you want. Otherwise fill in the template with a web site that describes the exact module(s) you want with physical dimensions and connector information.
@mkaira04 more specifically a website with physical dimensions, top view (flat) image, connector information.
Receiver: 433 MHz RF Receiver Module Pinout, Specifications, Equivalent & Datasheet
Transmitter & Receiver: 433MHz Transmitter & Receiver Modules with Antenna
The suggested google search turns up these two parts that appear to do what you want.
scroll down to
433Mhz RF transmitter and receiver link kit
(Transmitter module parameters):
thanks a lot vaneep but inside its just a lot of pics tho
you really helped me alot
It appears his github archive is gone (last time I accessed it which is probably a couple of years ago, it worked.) The parts however are available here
and
here (same site different file)
both load for me. I suspect these are copies of the original files before their home site went down as they match the pictures I think.
For others in the same situation I found the new files by doing a google search for " FS1000A – 433Mhz RF Transmitter"
and
" XD-RF-5V"
which are the links to the dead github archive (possibly due to the newish MFA stuff on github.) They contain the fzpz files which is what google found.
Hi Peter
The folder Fritzing-Custom-Parts/New Parts has been deleted (the repository exists)
I think the file is in here
Fritzing.parts.rar (6.1MB)
*Note: The latest GitHub release, which was published in 2023-01-19T16:00:00Z
As for the fzpz files:
FS1000A - 433Mhz RF Transmitter.fzpz (46.6 KB)
XD-RF-5V.fzpz (45.5 KB)
(I think)
Google doesn’t really update it (sometimes Google does not know that stuff have been deleted.
thanks a lot for the files
<3<3
Someone used one of the files above in a sketch and that indicated there are problems. As a result here are the two parts listed above fixed so they work correctly.
FS1000A-433Mhz_RF_Transmitter-fixed.fzpz (14.4 KB)
XD-RF-5V-fixed.fzpz (21.2 KB)
