I want a schematic representation of the model I mention about.
The pin layout is located at page 10 od the datasheet. Thanks!
This part should do what you want. Of note as usual if you want the mounting holes drilled you need to drag a hole from core parts->pcb in to the sketch, place it over the holes in silkscreen and set the hole size appropriately. As well the battery connector does not appear in pcb as it can’t be accessed in pcb.
challenger-rp2040-uwb.fzpz (24.3 KB)
