Hello Fritzing Community
I have attached a ZIP file containing all the necessary photos and the datasheet for this electronic component
I need this part to be available in Fritzing so I can use it in my electronic circuit designs and create accurate circuit diagrams and PCB layouts
Unfortunately I could not find this component in the existing parts library
I would really appreciate it if someone could create this part for Fritzing or help me make it compatible with the software
Thank you for your time and support
(T90-12VDC-TL-C6pin30A | Power Relays, Over 2 Amps | TLrelay | LCSC)*
*T90-12VDC-TL-C6pin30A
T90-12VDC-TL-C6pin30A.zip (2.3 MB)
