Request Stepper Motor Hat
Hello
anyone out there have or able to share a multi stepper motor hat for raspbery pi 3b+ or newer?
Im looking to add about 8 to 10 steppers for my project and need micro stepping at least 1/16 if not 1/32 will be using small Nema 8 or Nema 17 steppers
I’m thinking of using several of these that I found on Amazon…
thanks for any help :slight_smile:
There does not appear to be a Fritzing part for that particular board. There does appear to be one for this Adafruit board though (in the Adaftuit library on github although you should check out the Fritzing part before deciding to use it!):
otherwise someone would need to make a Fritizng part for the amazon board.
that helps thanks @vanepp !
thanks for the awesome information.
