I would need the x/y offset of the center of the pads where the wire connects from the edge of the pcb. The diameter of the holes is also needed to size an appropriate hole in pcb view (probably .038in which is a .1 connector hole). In breadboard and schematic those points are the connectors, in pcb there will be a pad where you could solder the board to a .1 single pin header if you were to install it on a board or install male pins on the board and female on the module and plug it in or as you say use wires. A proper part allows for all of these options.
edit: if you don’t want/need this level of detail then this existing part will likely do you it is somewhat smaller than the one you have so pcb won’t be quite correct, but if you use wires that won’t matter.
