Request for Fritzing parts: DFRobot Gravity ORP PRO, EC K=10, Turbidity Sensor, and Fermion NH3 Sensor
I would like to request Fritzing parts for four DFRobot water-quality / aquaculture-related sensor modules. I searched in Fritzing and online using the terms “fritzing part”, the SKU numbers, and the product names, but I could not find matching ready-to-use Fritzing parts for these exact modules.
Part 1
Name of the part :red_exclamation_mark:
DFRobot Gravity: Analog ORP Sensor Meter PRO
SKU: SEN0464
Manufacturer
DFRobot
Product / documentation links
DFRobot Wiki:
https://wiki.dfrobot.com/sen0464/
DFRobot product page:
https://www.dfrobot.com/product-2446.html
Previous work, similar parts
I could only find similar DFRobot Gravity analog sensor boards, but not this exact SEN0464 ORP Sensor Meter PRO Fritzing part.
Top view :red_exclamation_mark:
I will paste a top-view image of the SEN0464 signal converter board and probe connector here.
Important visible connector details:
  • Gravity analog output connector: PH2.0 - 3Pin
  • Probe/input connector: 5.08 mm / 0.20 inch pluggable connector
  • Board size: approximately 42 mm × 32 mm
Datasheet / official technical documentation :red_exclamation_mark:
Official DFRobot documentation:
Technical data :red_exclamation_mark:
Product type: Gravity analog ORP sensor meter / breakout board with industrial ORP probe
ORP signal converter:
  • Input voltage: 5 V
  • Input signal: 0.5 V to 4.5 V
  • Input interface: 5.08 mm / 0.20 inch pluggable connector
  • Measuring range: -2000 mV to +2000 mV
  • Output interface: Gravity PH2.0 - 3Pin
  • Module size: 42 mm × 32 mm
Industrial ORP probe:
  • Indicator electrode: Platinum
  • Reference electrode: Silver / silver chloride
  • Suitable temperature: 5 °C to 70 °C
  • Electrode potential: 245 mV to 270 mV
  • Reference electrode internal resistance: ≤10 kΩ
  • Electrode stability: ±8 mV / 24 h
Breakout board / Gravity sensor module.
No standard IC footprint applies.
Breakout board, sub assembly, plug in module
Part 2
DFRobot Gravity: Analog Electrical Conductivity Sensor / Meter (K=10)
SKU: DFR0300-H
Manufacturer
DFRobot
DFRobot Wiki:
https://wiki.dfrobot.com/Gravity_Analog_Electrical_Conductivity_Sensor_Meter_K%3D10_SKU_DFR0300-H
Alternative DFRobot Wiki short link:
https://wiki.dfrobot.com/dfr0300-h/
There are similar EC sensor parts for other DFRobot EC modules, especially K=1.0 versions, but I could not find the exact K=10 DFR0300-H board/probe combination.
I will paste a top-view image of the DFR0300-H board and probe connector here.
  • Probe connector: BNC
Product type: Gravity analog electrical conductivity sensor / meter for high-conductivity liquid
Signal conditioner board:
  • Supply voltage: 3.0 V to 5.0 V
  • Output voltage: 0 V to 3.2 V
  • Signal connector: Gravity PH2.0 - 3Pin
  • Measurement accuracy: ±5% F.S.
Electrical conductivity probe:
  • Probe constant: K = 10
  • Intended liquid type: high electrical conductivity liquid, such as seawater or concentrated brine
  • Measurement range: up to 100 ms/cm
  • Suitable for mariculture / marine aquaculture water quality applications
Part 3
DFRobot Gravity: Analog Turbidity Sensor for Arduino
SKU: SEN0189
Manufacturer
DFRobot
DFRobot Wiki:
https://wiki.dfrobot.com/sen0189/
https://www.dfrobot.com/product-1394.html
I found some generic turbidity sensor references, but I could not find a clean Fritzing part for the exact DFRobot Gravity SEN0189 module with its adapter board and sensor probe.
I will paste a top-view image of the SEN0189 adapter board and turbidity probe here.
  • Gravity analog/digital sensor adapter board
  • Signal connector for microcontroller
  • Separate turbidity probe connected to the adapter board
Product type: Gravity analog turbidity sensor module with probe
Main specifications:
  • Operating voltage: 5 V DC
  • Operating current: up to 40 mA
  • Response time: less than 500 ms
  • Output method: analog output and digital output
  • Analog output: approximately 0 V to 4.5 V
  • Digital output: adjustable threshold
  • Detection principle: uses light transmittance / scattering to estimate suspended particles and turbidity in water
  • Important note: the probe/sensor head is used in liquid, but the adapter board itself should be kept dry and protected from water.
Part 4
DFRobot Fermion: MEMS Ammonia NH3 Gas Detection Sensor
Breakout, 1–300 ppm
SKU: SEN0567
Manufacturer
DFRobot
DFRobot Wiki:
https://wiki.dfrobot.com/SKU_SEN0567_Fermion_MEMS_NH3_Sensor_breakout
Alternative DFRobot Wiki page:
https://wiki.dfrobot.com/sen0567/
https://www.dfrobot.com/product-2706.html
I could only find generic gas sensor or MQ-series Fritzing parts, but not this exact DFRobot Fermion MEMS NH3 breakout board, SKU SEN0567.
I will paste a top-view image of the SEN0567 breakout board here.
  • Small MEMS NH3 gas sensor breakout board
  • 2.54 mm pitch header pins
  • Board size: approximately 13 mm × 13 mm × 2.5 mm
Product type: Fermion MEMS NH3 gas detection sensor breakout
  • Gas detected: Ammonia / NH3
  • Detection range: 1 ppm to 300 ppm
  • Operating voltage: 3.3 V to 5 V
  • Operating current: less than 20 mA
  • Output signal: Analog voltage
  • Load resistance: 4.7 kΩ
  • Sensitivity: R0 in air / Rs in 50 ppm NH3 ≥ 3
  • Operating temperature: -10 °C to 50 °C
  • Operating humidity: 15% RH to 90% RH, non-condensing
  • Lifespan: at least 5 years in air
  • Dimensions: 13 mm × 13 mm × 2.5 mm
  • Application examples: ammonia leakage detection, aquaculture risk monitoring, cold storage, toilet odor monitoring, and other qualitative ammonia gas detection scenarios
Important note:
This is a gas-phase NH3 sensor. It is not a direct NH3/NH4+ water-quality probe. In aquaculture projects it should be used as an auxiliary gas/ammonia risk indicator, not as a laboratory-grade ammonia concentration measurement in water.
Small breakout board with 2.54 mm header pins.
Thank you. These four parts are needed for an IoT water quality and aquaculture monitoring project using DFRobot Gravity/Fermion sensors with an ESP32-S3 and an ADS1115 ADC.
