Request for Daly Smart BMS 3S12V60A Fritzing Part
Hello Fritzing Community,
I’m working on a project with the Daly Smart BMS 3S (Model: 3S12V60A Li-ion) and need to create a Fritzing part for circuit documentation. I have the official pinout documentation and would appreciate help creating this part.
BMS Specifications:
(Press the language selection button to view images of the connection wiring.)
Connector Overview:
The BMS has the following connectors:
  • Power terminals: P- and B- (screw terminals on top)
  • Cell voltage connectors: Two white JST-style connectors on the side
    • Voltage Collection 1 (电压采集1): B0, B1, B2, … B16
    • Voltage Collection 2 (电压采集2): B17, … B24
  • Communication connectors (4 white JST connectors on front):
    • 1× NTC-A (4-pin)
    • 1× UART-1 (6-pin)
    • 1× CAN/485 (5-pin)
    • 1× DIO/Reserved IO (5-pin, labeled 预留IO)
    • 1× KEY (4-pin)
    • 1× UART-2 (6-pin)
    • 1× NTC-B (4-pin)
Detailed Pin Assignments (from left to right on front panel):
NTC-A (4-pin):
  • Pin 1: NTC1
  • Pin 2: GND
  • Pin 3: GND
  • Pin 4: NTC2
UART-1 (6-pin):
  • Pin 1: RX
  • Pin 2: TX
  • Pin 3: S1
  • Pin 4: 12V
  • Pin 5: 3.3V
  • Pin 6: GND
CAN/485 (5-pin):
  • Pin 1: 485B
  • Pin 2: 485A
  • Pin 3: ABGND
  • Pin 4: CANH
  • Pin 5: CANL
DIO / Reserved IO (预留IO) (5-pin):
  • Pin 1: DO(3.3V) - Digital Output 3.3V
  • Pin 2: G (GND)
  • Pin 3: DI - Digital Input
  • Pin 4: G (GND)
  • Pin 5: DO(12V) - Digital Output 12V
KEY (4-pin):
  • Pin 1: KEY-
  • Pin 2: TBD (To Be Determined)
  • Pin 3: TBD (To Be Determined)
  • Pin 4: KEY+
UART-2 (6-pin):
  • Pin 1: RX
  • Pin 2: TX
  • Pin 3: S1
  • Pin 4: 12V
  • Pin 5: 3.3V
  • Pin 6: GND
NTC-B (4-pin):
  • Pin 1: NTC4
  • Pin 2: GND
  • Pin 3: GND
  • Pin 4: NTC3
Cell Voltage Connectors (for 3S configuration):
  • Voltage Collection 1: B0 (Battery -), B1, B2, B3 (only first 4 pins used for 3S)
  • Voltage Collection 2: Not used for 3S (supports up to 24S configurations)
Power Terminals:
  • P- (negative power output)
  • B- (battery negative input)
Would anyone be able to help create this Fritzing part or guide me through the process? I can provide additional photos or documentation if needed.
Thank you in advance for your help!
