Re SparkFun Electromechanical (Speaker PCB mount)
PCB Mount Speaker - already available on Fritzing but the terminals are switched(Red appears to be -ve and Black is +ve.
Is there a simple way for me to be able to switch this around so that Red = +ve and Black = -ve
Also, the termination seems to be midway along the pole (not too much of a problem, but aesthetically could do with termination point being at the end.
Many thanks in advanced
Could you please send me a file with the corresponding speakers.
Which version of Fritzing do you have?
Regards, Harald!
I am using the current version 1.0.8
The speaker that I am talking about is already part of Fritzing’s large parts inventory as follows:
Strangely enough, I have two of them. Let me take a look at it. I would then design a new part and fix it. The existing part can be difficult to change once installed. To do that, you would need to access the files in the part directory directly.
I don’t think I’ll get to it before Friday though — is that okay?
Best regards, Harald!
I once worked on a variant. Take a look at it. If anything else needs to be changed, just let me know.
As long as you’re not satisfied yet, you shouldn’t save this version in the parts library.
Lautsprecher_klein.fzpz (9.9 KB)
Second variant is perfect thank you
