Hi! Has anyone have this module
Raspberry Pi High-Precision AD/DA Expansion Board and EVAL-ADXL1002Z
Thank u so muchhh!!
Thank u so muchhh!!
You need to fill in the template you appear to have deleted with the web site for the part you want (presumably the Waveshare device here:
which a google search of the form “fritzing part Raspberry Pi High-Precision AD/DA Expansion Board” (which should be your first action to find any available parts) indicates there isn’t currently a Fritzing part for this board (assuming this is what you want.) Not enough information here to do anything with (the template is here for a reason!)
yes that is what I want
also this
Here is a part that implements the second request. Note pcb view has been suppressed as not useful.
EVAL-ADXL1002Z.fzpz (7.8 KB)
This part should do for the Wavehare board. Note pcb view has been suppressed as not useful.
waveshare_RPI_AD_DA_Expansion_module.fzpz (38.0 KB)
