Rasberry Pi NIOR Camera
Rasberry Pi NIOR Camera.fzpz (15.0 KB)
Thanks for the contribution @hafoard! Just note that it is the Raspberry Pi NOIR camera.
As well as the part file itself, a short text description would be helpful. With keyworks that might be used by someone searching for the part. People need to be able to locate this post later, if they are not downloading the part immediately.
HHELP…!
Not able to use the part in fritzing
Works as well as intended for me.
It is only useful in breadboard (like the image above) because it has no connectors (nor is there a camera connector in the PI parts) so it appears only in breadboard (although it appears in schematic and pcb which it should not!) , but there it works as it was presumably intended to.
Hi
I’ve created a new version of the file
Raspberry Pi NoIR Camera-fixed.fzpz (12.8 KB)
I’ve removed the schematic and PCB view
