I just wnated to check something.
Everytime I load Fritzing and scroll through the parts, it seems to be reloadng them, is this correct behaviour as it doesn’t seem right?
Thanks
Dave
Thanks
Dave
Define “reloading them”, changing parts bins will cause a screen update for the contents of the new bin and that is normal.
If you have text in the “find” box, Fritzing will do a search each time it loads to locate the matching parts. That is needed because Fritzing can not tell if the parts library and user parts have been modified since the previous time. What it (could) remember might be out of date. To prevent that, clear the search text box before closing.
Many thanks, yes I did have text in the’find’ box and understand why that would cause that behaviour.
Many thanks
