Prototype Shield V3.0 For Arduino Mega with Mini Breadboard fritzing part need
Hello Everyone!
I am in need of a Prototype Shield V3.0 For Arduino Mega with Mini Breadboard fritzing part for a science project, for which I have searched the internet for too long, but I couldn’t find it. If you happen to have it and can share it, I would be very grateful. Thank you very much!
We would need a web site to the board that you want, there appear to be several available.
Dear Peter,
Thank you for your answer. Here is the link for the part that I need exaclty:
Melinda
Before I invest work in this, a few questions: Do you need the prototyping pads (circled in red in this image?)
They are a lot of work to add and their position isn’t clear. Next issue is that the part will look like the image (i.e. no breadboard) as breadboards aren’t compatible within parts (the internals are different). The same effect can be had (with some inconvenience) by dragging a suitable breadboard over the part like this using a Uno as an example:
The downside is that unless you select both with a select rectangle they won’t move together. Staring from here (with some wires attached to the breadboard)
if I move the Uno the breadboard remains in place (you can then move the breadboard back to where it was though)
If this is acceptable I can make a part for the shield.
The angle is not the best, but it looks like the prototype pads at the right end are aligned with the final pin in the (top) side row of header pins. Then, the top most (short) row of pads appears to have a 0.1 inch offset from that side header row. Assuming the rest is a standard Arduino Mega shield footprint makes it possible. The surface mount pad position should not be critical, since there does not seem to be any mechanical interaction with the rest of the spacing. The hardest part there, is to get the bus right for the smd pad to prototype pad/hole. It would ‘nice’, if could drop a bare chip on that and get the connections.
Does not help with the ‘work’ part, but should be enough for the positioning.
I agree it is likely possible (if a lot of work) to do something about the prototype area. The best outcome will be if he or she doesn’t need the prototyping area just the Mega pins and the breadboard and doesn’t mind the issue with the breadboard being separate. That is a lot less work. Just modify a copy of the mega to add the extra back connectors (if needed) or better yet use the existing mega connector for them, rather than add several hundred new connectors. Come to think of it, the proto connections are going to need to be in a breadboard part, as a custom breadboard just for this shield, as the proto area is a form of breadboard and thus needs to be in a breadboard part (I think!) to not reflect in to schematic and pcb! As far as I can see the ICSP connector is floating, it doesn’t seem to have any way of connecting to the Mega’s ICSP connector that I can see (there are more pictures in the datasheet, unfortunately none clearer though!) although I may well be missing something. I guess I’ll wait and see what the OP wants to do and/or what they need it to do and see if I am willing to try it.
Hello
I also need this shield (without the breadboard). I only found v6 but that is completely different.
Maybe someone could help. THX
A google search for “prototype shield v6 for arduino mega”
turns up this Fritzing part. Try that.
https://paulvollmer.net/FritzingParts/parts/proto_shield_v6MEGA.html
This is v6, we need v3.
Then you need to provide the pointer to a mechanical drawing for the board you want (with the warning it is a lot of work for not much gain as noted above!) As there appear to be several versions.
Hi, I am using this same board, was this part maybe developed?
https://www.google.com/imgres?q=arduino%20CMU%20MEGA%20PROTO%20SHIELD%2BBREADBOARD&imgurl=https%3A%2F%2Fkuongshun.com%2Fcdn%2Fshop%2Fproducts%2F3_1_0d37b17a-6b30-49be-9090-b6f3a4a05cc7.jpg%3Fv%3D1556605413&imgrefurl=https%3A%2F%2Fkuongshun.com%2Fproducts%2Fmega-2560-proto-prototype-shield-v3-0&docid=-Wba0p0NvWIC2M&tbnid=U5vCiO9KRsI5mM&vet=12ahUKEwie2KW1kKSFAxWXXvEDHUEpCZ4QM3oECC4QAA..i&w=1000&h=1000&hcb=2&ved=2ahUKEwie2KW1kKSFAxWXXvEDHUEpCZ4QM3oECC4QAA
No and a new one is a lot of work for not much. Try one of the suggestions above for alternatives.
This proto shield in core parts is likely as close as you will get.
Hello, it is now avaialbe here https://forum.fritzing.org/t/breadboard-shield-for-arduino-mega-fritzing-part/34734
It has two versions, with and without breadboard as below:
