Program will not let me Continue
as soon as I put an IC on my proto board and I click on save, I get this message:
Failed to write part ‘4011 bla, bla.’ to C:/Users/ricka/One Drive/Desktop/FritzFiles/MB-TEST.fzz’.
zip error writing part files
Since I deleted OneDrive from my computer, I can see that might be a problem, but even when I select Save As and I delete On Drive so I have C:/Users/ricka/Desktop/FritzFiles/MB-TEST.fzz, I get the same message. So the program goes into a never ending revloving blue circle and the only thing I can do is delete my IC and quit. It will not let me proceed. I need to make the program accept my save path without one drive and even though I write in the new path It responds, It does not recognize the path.
Hi!
Does this also happen if you use a 4011 part from the “Core” bin?
Are you already using Fritzing 1.0.8, and did you create the “4011 bla bla” part with an older (1.0.6 or before) ?
It might be that Fritzing still remembers the “4011 bla bla” part in “My Parts” bin, but can’t read the exact files anymore (because the One Drive was removed)
Greetings, Kjell
