Hi
I am relatively new to Fritzing, so please excuse me if this is a daft question,but I have read all the tutorials etc.
If I add a component. and then double click an existing wire to make a connection point, it is quite often impossible to make the 2 join as an electrical joint. I have tried every combination of Ctrl/Alt etc keys without success. It only seems to work if you work your way along somehow, adding new lengths of wire after connecting a new component
I am sure there must be an easy way to achieve this - anybody ???
Try holding down the Alt key only and drag form the bend point, or drag from the connector to the bend point.
Edit: Sorry, that only works on the pcb and schematic view… on the breadboard view they need to connect to a breadboard socket or a connector.
If it’s BB view, you right-click in the middle of the wire and Add bendpoint, then right-click one side of the wire and Delete wire to bendpoint, then add a wire starting from a component or drag a remaining wire to the bendpoint. Alt Doesn’t work in BB.
I tried that, it didn’t work… It only seams to work with bendable legs…
Opps. You can physically put the wire on the bendpoint, but it doesn’t connect.
EDIT
I just realised you can’t do it in real life, so why would you be able to do it in FZ BB view.
I keep my breadboard view checked for curvy wires… just like real life…
Sooner or later you will come over to the Dark OCD Straight Line Side.
Hi Old_Grey
Thanks to all of you for your feedback, between all the comments I think I have worked out the issue.
My design had a bunch of relays “floating”, in other words, not on a breadboard at all. That is where the problem comes in, for some strange reason, Fritzing only likes to allow connections to components that are on a breadboard. Once they are "floating in the BB space then you get these problems.
I suspect it is a shortcoming of the software that perhaps other ore experienced users would not even try to do ??
Maybe the Authors will take note and fix that issue ?
Cheers guys - it is a great utility nevertheless…!!
I want to help you with better user experience.
Thanks for this answer. It worked in my case wonderfully.
