That may be a good bet. If you don’t have custom parts (or maybe even if you do) try removing the user files too as they won’t get changed during a reinstall and something in there may be the issue.
linux
~/Documents/Fritzing/parts
~/.config/Fritzing
Mac
~/.config/Fritzing
It may also be worthwhile to upload the sketch with the corrupted image loaded (the .fzz file, upload is 7th icon from the left in the reply menu.) I can extract the png image from the .fzz file and see if it is corrupted there and if it displays correctly here.
