Problem with junction cable in tab "platine d'essais"
Hello everyone,
I’m having a problem with the “Breadboard” tab.
I followed this video, working on the “Schematic View” tab.
“Fritzing Advanced Tips & Tricks - pt2” in youtube
I’m having trouble connecting several wires that share the same power source. When I hover the mouse over the Arduino 5V pin, all the connections (markers) are yellow (indicating they are properly connected).
![Fritzing - Platine d’essais_2|689x467]
However, when I bridge the 5V supply of the four IR boundary sensors on the same wire going to the Arduino 5V pin, the connections are not formed.
Thank you for your time.
That “same wire” is likely the problem. Fritzing does not allow connecting to the middle of a wire. Various options. place a single point terminal and connect to that. Run wires over top of each other making it look like a wire with taps off of it.
Thanks for the information.
I’ve simplified the drawing by adding the necessary terminal blocks for connecting the external components to the PCB.
Here’s the result.
Since I’m practically unfamiliar with this area, could someone with experience take a look and verify it?
Thanks in advance for your time.
