Hello, is someone know to to get Probe the part for PH-4502C (PH Sensor?)
Thanks!
One of these may do what you want.
yes, but i need the probe
Is there any? thanks
There is this one for the DFR sensor (the part in the original post no longer loads because the sensor is now in core parts)
DFRobot-PH-sensor.fzpz (34.5 KB)
and I made a part for someone with the probe for the other sensor but I can not currently find that part either on my system or in the forum although it was posted here.
edit
Ah! found it.
analog-ph-sensor.fzpz (26.7 KB)
thanks very much
Good day Guys i am looking for NPK ph sensor library
Are you looking for a Fritzing part or a code library? There doesn’t appear to be a Fritzing part at present although it is relatively easy to make one.
if anyone has got the Fritzing part , that will be very much better for me
