I have some cheap Pro Mini boards that use a 168p (see images). My problem is I cant find any part that matches this layout. The analog pins are in a different location from the pro minis that come as default.
Can anyone help me modify a pro mini to match this layout? Hopefully it just requires moving the pins of an existing pro mini around a bit?
This image I found on the forum seems to be the same layout
