12V 30W pump
Please edit this message to let us know exactly what electronic part we are talking about. Creating parts is some work, so please be considerate and make it easy for us.
We need the title, an image and the technical data, fields are marked with a :red_exclamation_mark: . Without this infomation, the part can not be created.
Search the part prepare before posting.
You can search for the part here:
Name of the part​:red_exclamation_mark:
PUMP DC 12V 30WATT
<This picture shows the part from above, so that is easy to see were connectors should go, and which diameter they have.>
https://www.bldcpump.com/downloads/BLDC%20PUMP%20DC30A.pdf
Please add a link to PDF of the manufacturers datasheet. **
[.] Motor (M)
