Pololu logic level shifter # 2575
Please edit this message to let us know exactly what electronic part we are talking about. Creating parts is some work, so please be considerate and make it easy for us.
We need the title, an image and the technical data, fields are marked with a :red_exclamation_mark: . Without this infomation, the part can not be created.
Search the part prepare before posting.
You can search for the part here:
Name of the part❗ Logic Level Shifter, 4-Channel, Bidirectional # 2575
IT would be great if this could be made in “right side up” AND “upside down” - sometimes i need the HV on one side and sometimes on the other… if you get my drift.
THANK YOU
Top view❗
<This picture shows the part from above, so that is easy to see were connectors should go, and which diameter they have.>
Datasheet❗
https://www.pololu.com/file/0J2020/ls01a-drill.dxf
https://www.pololu.com/file/0J1591/logic-level-shifter-4-channel-bidirectional.step
DIP - 0.3” X 5 PINS EA SIDE
You can (and will probably need to if you want the parts) do this for yourself with the generic IC. This tutorial details the process:
