I am looking for the Pololu High-Power Stepper Motor Driver 36v4
I was going see if anyone has made a part file for this stepper driver board.
This part should do what you want. Note the mounting holes are not drilled by default. If you want mounting holes drilled you need to drag the hole icon from core parts/pcb in to the sketch, place it over the hole in silkscreen and set the size appropriately.
pololu-36v4.fzpz (14.5 KB)
