Pololu D36V50F5 and S7V8F3
Hello again. Can I have a fzpz file for the following buck converters?
D36V50F5: Pololu - 5V, 5.5A Step-Down Voltage Regulator D36V50F5
S7V8F3: Pololu 3.3V Step-Up/Step-Down Voltage Regulator S7V8F3
Also, can I have a fzpz file for a USB C charging port? I intend to use it since I will be using 2 TP4056 then connect it to one charging port.
Thank you so much!
A google search of the form “fritzing part D36V50F5” indicates there is a part here:
a google search for “fritzing part S7V8F3” indicates there is a part here
Actually, the components came from the same brand but with different specifications. Does this work the same?
Don’t know, you need to look at the listed parts and see if they do what you want. usually the part number describes the same part (although sometimes they upgrade them with the same part number.)
How about this component? Pololu U3V70F5. I haven’t seen someone posting about this yet. Its size is different from the usual polulu buck converters.
Pololu - 5V Step-Up Voltage Regulator U3V70F5
This is a step-up converter
