Plss make ltc3108
Name of the part​:red_exclamation_mark:
LTC3108 Ultralow Voltage Step-Up Converter and Power Manager (IC)
I searched the Fritzing parts library and forum but could not find a dedicated Fritzing part for the LTC3108 IC.
Please refer to the top-view package drawing in the official LTC3108 datasheet. I will attach a top-view image of the IC package with the pin configuration clearly visible.
Official datasheet by Analog Devices:
https://www.analog.com/media/en/technical-documentation/data-sheets/LTC3108.pdf
The LTC3108 is available in two package options:
  • 12-lead DFN, 4 mm × 3 mm, with exposed thermal pad.
  • 16-lead narrow SSOP.
A separate Fritzing part may be needed for each package variant.
[ ] I did not read this
[ ] Breakout board, sub assembly, plug in module (A)
[ ] Antenna (AE)
[ ] Battery (BT)
[ ] Capacitor (C)
[ ] Diode (D)
[ ] Display (DS)
[ ] Fuse (F)
[ ] Hardware (H)
[ ] Jack (J)
[ ] Relay (K)
[ ] Inductor (L)
[ ] Loudspeaker (LS)
[ ] Motor (M)
[ ] Microphone (MK)
[ ] Plug (P)
[ ] Transistor (Q)
[ ] Resistor (R)
[ ] Thermistor (RT)
[ ] Varistor (RV)
[ ] Switch (S)
[ ] Transformer (T)
[yes] Integrated Circuit (IC)
[ ] Other
Is there an SVG file with exact dimensions for this, or better yet, a footprint?
I have a part here that could be used to build the desired component. You can find it in Fritzing under “max98306”
Best regards, Harald!
