Please help! KS5016 Keyestudio ESP32 Dev Board
I am using a KS5016 Keyestudio ESP32 Dev Board in my project but I could not find any fritzing files online or in any libraries. Please could someone create this part for me? I would be very grateful.
link: https://wiki.keyestudio.com/KS5016_Keyestudio_ESP32_PLUS_Development_Board
Thank you,
Umair
Fix two typos in the pin labels and replace the part.
edit Oct 2025 replace part with a new part to correct the version number so Fritzing 1.0.5 doesn’t complain on load. New moduleId so will load beside the old part.
keystudio-KS5016.fzpz (48.4 KB)
Hi Peter,
Thank you so much for creating this.
I just wanted to highlight, however; you labelled some pins incorrectly. Namely the io pins 6 and 22 which should be 5 and 23 respectivley.
Again I greatly appreciate you for creating this part.
Regards,
Umair
I should have mentioned that some of the pins may be wrong. The jpg isn’t that clear
it appears to be a 6 in the image, the 22 is indeed 23 in the image so a typo. I’ll correct both and replace the part.
