Has anyone created a template for the Pi Zero? I’m after a PCB template for making a HAT like the other Pi ones available.
I’ve had a go but may have the dimensions slightly off so wondered if there’s a more polished one available anywhere.
Thanks
Thanks
Why are your dimensions slightly off? What program did you use for layup? I am personally not up to speed on the availability of this said part. But if you are close, let’s go ahead and finish this one off. maybe share a link to the specifications and your current file? I’m sure it can be done, exactly as specified.
Have a great day!!
