I want to build a device for measuring pH, TDS/Ec, ORP and temperature using Arduino. Can you help me with a diagram and sketch? Perhaps you have already seen the finished product somewhere? I will be very glad if you help me
There are Fritzing parts for PH and TDS (I have no idea if it also does Ec), I have no idea what ORP is and there are a variety of temperature sensors available. In general a google search of the form "fritzing part part number: (where part number is the part you need) will find Fritzing parts that people have made. Good luck.
this is the orp sensor, can you do it please
Likely if I knew what an ec meter sensor was. You would need to provide a web site which describes what you want with physical dimensions and connector information. Assuming it is DfRobot, the product page should do.
https://www.dfrobot.com/product-1123.html & Gravity__Analog_Electrical_Conductivity_Sensor___Meter_V2__K=1__SKU_DFR0300-DFRobot
is this information enough?
Yep. A google search of the form “fritzing part dfr0300” (which is the best way to find existing parts) indicates a part is available here:
