MPX700AP… can you help me?
Are you looking for just the sensor or the sensor mounted on a breakout board? There doesn’t appear to be a Fritzing part, and to make one we would need more information such as a web page for the part you want.
terimakasih akhirnya aku bisa merangkainya untuk tugas akhir
Hai!
Ada yang punya bagian ini? MAX30100
Yes although I screwed up the article reference in your original post (I just corrected it so if you check your original request the link should now work.)
