I’m attempting to create a PCB which will have 20 LED’s and for the time being, will be powered by a 9V battery until I can get a little further into the project. It is started on a perfboard and have a stack of perfboards to use to get it right.
I wanted to know if the attached file will work. I used an LED online calculator to help group the LED’s.
The PCB is the only portion of the file that is of interestFlames_small_perfboard.fzz (12.4 KB)
Thanks
Scott
