Hi, I am a newcommer to Fritzing. I have a PCB that just won’t export the drilled holes.txt file. I built the circuit in the schematic view (kinda just how i understand EE) and when i went to export the file (after auto routing) it doesn’t export the drill.txt
I am using a custom Cherry MX switch that is supposed to have all the holes pre-determined
Works for me on Fritzing 0.9.6 on Win 10. You have a large number of DRC (routing->Design Rules Check) though although that isn’t affecting the export.
I do not know if this is the cause, but the cherry key part in your sketch has some errors.
The layer id is missing from both the breadboard and schematic svg view files
bus entries are defined in the fzp metadata, but the referenced connectors do not exist
There are others, but more cosmetic.
What operating system and version of Fritzing are you using? The gerber export works for me as well using Fedora 33 and Fritzing 0.9.6. I get at drill file
oh dang
im using Windows 10, Frizting 0.9.6
considering that others can export the files and I cannot despite having the same system (I cannot export drill.txt in any circuit) I think its safe to say its my program that is messed up
I’d suggest reinstalling Fritzing as it looks like the gerber output processing has gotten corrupted somehow. I can also clean up the custom parts which should fix some of the odd drill sizes.
You likely need to check the DRC output too. It is reporting that some of the traces are too close and/or overlapping which can cause problems on the board. As well I made a part for someone last night for sockets that fit the MX2 keys (available from Adafruit) that you may be interested in.
You will need to delete the current part (delete minus will delete the part but leave the traces) in every where, then shutdown and restart Fritzing to actually delete the part before it will let you load the new one. The original part has holes that are too small: This is the data sheet for the Cherry MX from Digikey with the recommended PCB layout. As you see the holes in the original part are too small and the key isn’t likely to fit.
