What is the best way to create extra pads on a PCB that do not show up in the schematic or breadboard view. I just need an extra power and ground connection to go to another PCB for a 3PDT footswitch. I see you can add a pad, but I want it to be a hole. Should I just use a Via with a 1mm hole and .5 ring thickness?
Thanks
